Go to primary content
Oracle® Retail Service Backbone (RSB) Release Notes
Release 16.0
  Go To Table Of Contents
Contents
Previous
Previous
Release Notes
Release 16.0
E82043-01
December 2016
This document highlights the major changes for Release 16.0 of Oracle Retail Service Backbone (RSB).
Overview
Common integration patterns used for interoperability of the applications include asynchronous messaging (fire and forget), request response, and bulk data transfer. In Oracle Retail, Retail Integration Bus (RIB) is used for asynchronous messaging and ODI is used for bulk data transfer. Retail Service Backbone (RSB) uses the request-response style of Enterprise Integration in Oracle Retail. RSB uses Web services as the mechanism for the request/reply style of integration. RSB products include pre-built services and flows and the integration API end points for all of the Oracle Retail Application's Web services and the Enterprise Solution Web service integration points and contracts for external application to connect to as part of the Solution business processing. RSB is an uptake of Oracle Service Bus (OSB) for Retail domain.
Both RSB and RIB use Retail Business Object (RBO) for the messages. This ensures consistency and interoperability between the integration patterns. In addition to this, there are common tools like Retail SOA Enabler (RSE), Retail Integration Console (RIC) that work with both styles of integration products.
In other words, Oracle Retail Service Backbone (RSB) is a product comprised of a set of Web services, an enterprise service bus (ESB) and security tools that standardize the deployment and runtime of Web service flows within Oracle Retail Suite of applications.
RSB can also be viewed as a set of pre-built Web service integration API end points delivered by Oracle Retail.
Hardware and Software Requirements
See the Oracle Retail Service Backbone (RSB) Installation Guide for information about the following:
  • Hardware and software requirements
  • Oracle Retail application software compatibility
Functional Enhancement
The following functional enhancement is included in this release:
Converge Commerce Solution Pack
A solution pack has been added to RSB to support the new solution, Oracle Commerce Retail Extension Module (RXM). This solution pack allows the converged commerce solution, RXM, to communicate with Oracle Retail Customer Engagement. For more information about RXM, see its documentation library on the Oracle Retail documentation site.
Supplemental Training
The following documents are available through My Oracle Support. Access My Oracle
Support at the following URL:
https://support.oracle.com
Transfer of Information (TOI) Material (Doc ID 732026.1)
For applicable products, online training is available to Oracle supported customers. These online courses provide release-specific product knowledge that enables your functional and technical teams to plan, implement and/or upgrade and support Oracle Retail applications effectively and efficiently.
Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Oracle® Retail Service Backbone (RSB), Release Notes, Release 16.0
Copyright © 2016, Oracle and/or its affiliates. All rights reserved.
This software and related documentation are provided under a license agreement containing restrictions on use and disclosure and are protected by intellectual property laws. Except as expressly permitted in your license agreement or allowed by law, you may not use, copy, reproduce, translate, broadcast, modify, license, transmit, distribute, exhibit, perform, publish, or display any part, in any form, or by any means. Reverse engineering, disassembly, or decompilation of this software, unless required by law for interoperability, is prohibited.
The information contained herein is subject to change without notice and is not warranted to be error-free. If you find any errors, please report them to us in writing.
If this is software or related documentation that is delivered to the U.S. Government or anyone licensing it on behalf of the U.S. Government, then the following notice is applicable:
U.S. GOVERNMENT END USERS: Oracle programs, including any operating system, integrated software, any programs installed on the hardware, and/or documentation, delivered to U.S. Government end users are "commercial computer software" pursuant to the applicable Federal Acquisition Regulation and agency-specific supplemental regulations. As such, use, duplication, disclosure, modification, and adaptation of the programs, including any operating system, integrated software, any programs installed on the hardware, and/or documentation, shall be subject to license terms and license restrictions applicable to the programs. No other rights are granted to the U.S. Government.
This software or hardware is developed for general use in a variety of information management applications. It is not developed or intended for use in any inherently dangerous applications, including applications that may create a risk of personal injury. If you use this software or hardware in dangerous applications, then you shall be responsible to take all appropriate fail-safe, backup, redundancy, and other measures to ensure its safe use. Oracle Corporation and its affiliates disclaim any liability for any damages caused by use of this software or hardware in dangerous applications.
Oracle and Java are registered trademarks of Oracle and/or its affiliates. Other names may be trademarks of their respective owners.
Intel and Intel Xeon are trademarks or registered trademarks of Intel Corporation. All SPARC trademarks are used under license and are trademarks or registered trademarks of SPARC International, Inc. AMD, Opteron, the AMD logo, and the AMD Opteron logo are trademarks or registered trademarks of Advanced Micro Devices. UNIX is a registered trademark of The Open Group.
This software or hardware and documentation may provide access to or information about content, products, and services from third parties. Oracle Corporation and its affiliates are not responsible for and expressly disclaim all warranties of any kind with respect to third-party content, products, and services unless otherwise set forth in an applicable agreement between you and Oracle. Oracle Corporation and its affiliates will not be responsible for any loss, costs, or damages incurred due to your access to or use of third-party content, products, or services, except as set forth in an applicable agreement between you and Oracle.
Value-Added Reseller (VAR) Language
Oracle Retail VAR Applications
The following restrictions and provisions only apply to the programs referred to in this section and licensed to you. You acknowledge that the programs may contain third party software (VAR applications) licensed to Oracle. Depending upon your product and its version number, the VAR applications may include:
(i) the MicroStrategy Components developed and licensed by MicroStrategy Services Corporation (MicroStrategy) of McLean, Virginia to Oracle and imbedded in the MicroStrategy for Oracle Retail Data Warehouse and MicroStrategy for Oracle Retail Planning & Optimization applications.
(ii) the Wavelink component developed and licensed by Wavelink Corporation (Wavelink) of Kirkland, Washington, to Oracle and imbedded in Oracle Retail Mobile Store Inventory Management.
(iii) the software component known as Access Via™ licensed by Access Via of Seattle, Washington, and imbedded in Oracle Retail Signs and Oracle Retail Labels and Tags.
(iv) the software component known as Adobe Flex™ licensed by Adobe Systems Incorporated of San Jose, California, and imbedded in Oracle Retail Promotion Planning & Optimization application.
You acknowledge and confirm that Oracle grants you use of only the object code of the VAR Applications. Oracle will not deliver source code to the VAR Applications to you. Notwithstanding any other term or condition of the agreement and this ordering document, you shall not cause or permit alteration of any VAR Applications. For purposes of this section, "alteration" refers to all alterations, translations, upgrades, enhancements, customizations or modifications of all or any portion of the VAR Applications including all reconfigurations, reassembly or reverse assembly, re-engineering or reverse engineering and recompilations or reverse compilations of the VAR Applications or any derivatives of the VAR Applications. You acknowledge that it shall be a breach of the agreement to utilize the relationship, and/or confidential information of the VAR Applications for purposes of competitive discovery.
The VAR Applications contain trade secrets of Oracle and Oracle's licensors and Customer shall not attempt, cause, or permit the alteration, decompilation, reverse engineering, disassembly or other reduction of the VAR Applications to a human perceivable form. Oracle reserves the right to replace, with functional equivalent software, any of the VAR Applications in future releases of the applicable program.
